Anchor mount
Published date: May 11, 2009
  • Boat Type: Boat Type
The anchor locker is small on the 26x. Also the anchor is hard to get to, especially if you need to set fast, such as if the engine quits in a tight area. I used a West Marine rail mounting bracket to mount the Fortress FX11, with a vinyl covered anchor chain attached to a conventional chain, and a Blue Water Marine anchor roller. If I am going on a trip, I sometimes put the smaller 8 lb anchor in the locker, as a backup.
Published by: AndreEmmenegger
Model Year: 2000
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Ronca anchor and beefier roller
    Anchoring - - November 3, 2007
    I've a heavier West Marine (Lewmar) articulating anchor roller http://tinyurl.com/ytycty , of moderately heavy SS, bolted through a 3/8 inch aluminum plate/bowsprit (~ 4" x 2 ft.), which is in turn bolted through the foredeck and through a triangular...
  • Anchor
    Anchor
    Anchoring - - July 2, 2007
    We fitted this anchor for looking at, the sand anchor we throw in the water is stored in the locker Jack Sparrow Published by: Jack Sparrow
