vberth panels
Published date: May 29, 2009
  • Boat Type: Boat Type
Although replacing the light "plastic" v-berth cover panels with plywood is the prevailing and most likely the best best method to keep from falling into the water ballast compartment when climbing through the front hatch, I did not feel like cutting/sanding/sealing/staining/painting etc so I used a some light aluminum strips (on the top) thick enough that I could countersink the 3/4 inch #6 flat head nuts and bolts, crazy glue (don't use sets/drys to fast) and epoxy (use one that sets in 15 - 20 minutes) and a light aluminum angle (on the underside) to keep them from bending in the center and falling through. I believe the glue/epoxied combination is helpful in creating a better resistance to bending than the 3 individual materials just bolted together. I cut away the angle so the aluminum ran all the way to the edge. Total time - about 2 1/2 hours and cost about $30 in materials (I had the glues and screws so it is an estimate)
Published by: tangentair
Model Year: 2006
Photo Caption: vberth panels
Share
Related Mods
  • V-Berth privacy curtains
    Berths - - May 2, 2009
    Privacy curtains added via an RV ceiling track. This turned out to be a very clean look! Published by: Bumpcity
  • Forward berth privacy curtain
    Berths - - January 10, 2009
    Privacy Sleeping Curtains: Replaced the curtain holder with an aluminum rod and installed nicer curtains Published by: Qu├ębec 1
  • Plastic bed springs for V-berth
    Berths - - August 26, 2008
    At last year's Norfolk (VA) Boat Show, one of the vendors was selling "Froli" plastic bed-springs ... they are square, flower-like plastic cups on cross-shaped bases, that snap together to make an open-air sort of bed spring system for boat bunks. I ...
