Fresh water tank
Published date: April 3, 2001
  • Boat Type: Boat Type
This is my fresh water system. 8 gal plastic tank set under V Berth two small 12 volt electric pumps are wired directly to faucets located in galley and head. The extra weight of the water when sailing the older Macs (prior to front air relief change) realy helps the Mac sail better empty the tank enroute back to Marina and bow lifts under power. Sort of an automatic ballast system with frsh drinking water.
Published by: MS Classifieds
Model Year: 2001
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
