Galley and Head 12 volt Faucets
Published date: April 3, 2001
  • Boat Type: Boat Type
12 volt water faucets come with mini 12 volt pumps as a combo or sold seperately for replacement. Push the button and you have water. Add a 10 foot long hose and kitchen spray gun to end of faucet (slips right on ) and you have a fresh (but cold) shower nozzle that reaches the cockpit. Pumps screw right into water tank.( see tank photo).
Published by: MS Classifieds
Model Year: 2001
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
