easy trailer hooking
Published date: July 31, 2009
  • Boat Type: Boat Type
For easy coupling the trailer to the car alone i have a truck mirror bolted to the ladder with wingnuts so i can see where i am backing so i easy hitting the trailer in first try ... Use some pieces of steeltubes and flatbars for making the mirrorarm - most handymens fix it easy . For preventing bendt & hooked wire eyes - especially on backstay - when i am raising the mast alone i covered the wire ends with short pieces of splitted plastic tubes ... Ekscuse me that im not computer experienced enough for sending pictures of my boat - hopefully i one day will learn how to do it ... I have just mounted new wheelbearings and i added new extra sealingrings for protecting bearings from salty water - there are space enough for extra innersealings ! Fill the new sealings with grease and oilsoaked foam for lubricating the sealing !!
Published by: arvid
Model Year: 2000
Share
Related Mods
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
  • norwegian spesial
    norwegian spesial
    Trailer - - July 25, 2009
    The trailer need a rollersystem instead of the original rigid bed in front , i have long rubber rollers on sides and a keel roll aft of them . Published by: arvid
  • Norwegian special
    Norwegian special
    Trailer - - July 18, 2009
    A dream came true when i got a 26x last year - but it needed a lot of modifications ... I have extended the toilet room so it fits adults - open the door halfways and make the frontwall 40 cm longer and a 20 cm long centerwall and make a roof and reb...
