Rewiring
- Boat Type: Boat Type
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory needed access to bolts attaching various things. This is convenient for us since you can just pry off the covers and push wires through the conduits. When you pry off the covers, locate the things on the sides that pop out to keep them in place. Push these in with a screwdriver as you pry, and the cover pops right off.
I also found that there were a few places (maybe five or six) where there wasn't a convenient hole already there, and where I needed to turn or guide various wires. No problem. Just attach a one-inch hole saw to your drill and make a few new holes. Then when you're finished, pop in some one-inch white plastic hole covers. Tadaa!
Published by: Heath
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
Rewiring, Bus BarElectrical - - April 27, 2000
This shows a closeup of the bus bar. OK, I didn't solder and heat-shrink the connectors. But you should. All the wiring is Ancor marine-grade. We had trouble with both the bow and stern running light connections and I had to take off the lights, dril...
