Manson Supreme Anchor
Published date: August 11, 2009
  • Boat Type: Boat Type
In preparing the boat for the Bahamas,we have added a serious anchor,a 25 lb Manson Supreme. This thing just glues itself to the bottom! We added an upgraded roller to support it and added a cleat capable of handling a mooring line at the same time. To hold it securely it was drilled and a pin with a j clip was inserted through the anchor and roller. The anchor shank was trimmed in order to accomodate the furler,eliminating the "trip line slot"
http://www.defender.com/product.jsp?path=-1|10391|33872|902122&id=901916
Published by: KayakDan
Model Year: 2006
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Anchor mount
    Anchor mount
    Anchoring - - May 11, 2009
    The anchor locker is small on the 26x. Also the anchor is hard to get to, especially if you need to set fast, such as if the engine quits in a tight area. I used a West Marine rail mounting bracket to mount the Fortress FX11, with a vinyl covered anc...
  • Ronca anchor and beefier roller
    Anchoring - - November 3, 2007
    I've a heavier West Marine (Lewmar) articulating anchor roller http://tinyurl.com/ytycty , of moderately heavy SS, bolted through a 3/8 inch aluminum plate/bowsprit (~ 4" x 2 ft.), which is in turn bolted through the foredeck and through a triangular...
