Skene chocks and heavier cleats
Published date: August 24, 2009
  • Boat Type: Boat Type
I didn't trust the factory-standard bow cleats, so I replaced them with 8" Herreshoff-style SS cleats from Bosun Supplies. Later I added 4" Skene chocks from Bosun Supplies, which I put in place with G-Flex thickened epoxy rather than 5200 (for extra strength).
I was fortunate that my boat had an "access plate" under the anchor locker, to put in the cleats. I used 3"x8" plates of 3/4" marine plywood as backing plates, and the widest-available fender washers under that. (Bosun Supplies recommended wood rather than metal, because the wood has some "give" and will absorb stresses better.) There's not much room to get at this; you will need a helper above-decks to unscrew the old cleats, and later to screw in the new ones (while you hold a wrench to the Nylock nuts). It was a jigsaw-puzzle getting all the flotation foam back into the bows.
Added the Skene chocks when I found the anchor rode tended to slip across the bow light. These were so close to the edge of the deck that I knew I wouldn't be able to through-bolt them. Bosun Supplies provided #10 screws to attach them, and I chose the strongest marine epoxy I knew to "bed" them (and for added strength). Since the Skene chocks don't get "pulled" like the cleats, I (have to) trust that this will be adequate.
Published by: Rick Westlake
Model Year: 1999
Photo Caption: Bow cleats and Skene chocks, from ahead of the bow
Skene chocks themselves, from above
Backing plates under the bow cleats
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Stern anchor
    Stern anchor
    Anchoring - - August 24, 2009
    This "tube mount" puts a reasonable-sized stern anchor in easy reach from the helm. I'm using a Fortress FX-11 in mine, which is close in size to a 13-lb Danforth. Other-style anchors with similar-sized stocks would probably fit as well. I used 3-inc...
  • Manson Supreme Anchor
    Anchoring - - August 11, 2009
    In preparing the boat for the Bahamas,we have added a serious anchor,a 25 lb Manson Supreme. This thing just glues itself to the bottom! We added an upgraded roller to support it and added a cleat capable of handling a mooring line at the same time. ...
