Fuel-water separator
Published date: September 16, 2009
  • Boat Type: Boat Type
Thanks to ethanol blends, water contamination in our fuel is an even greater worry. My answer was to add a pre-filter, AKA fuel-water separator, to my system. I bought this Honda re-label of a Racor low-flow model for its compact size, but there's plenty of room for the next size up. (You can see where I mounted the filter in the photo of my transom; it's next to the red bulge of my fuel tank.)
The 90-degree elbow is the inlet hose, which has the fuel-tank connector from my old fuel hose (which I had to replace due to a leaky engine-side connector). I secured this hose a few inches below the filter, so I can put a container under the bowl when I need to drain it and replace the filter element. I can shift the inlet hose from tank to tank in a couple of seconds. I put a fuel-tank "bayonet" on the filter's outlet, so I can bypass the filter altogether if it gets badly clogged from one tank's gas.
With the clear filter bowl, I can see any contamination before it's a problem. It's easy to screw off the bowl to drain it; but I'd recommend the next-larger Racor, with a quick-drain on the bowl, if you do this yourself.
Published by: Rick Westlake
Model Year: 1999
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Gas Tanks - Installation & Draining
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • Spray Rails
    Spray Rails
    Motor - - January 3, 2009
    Hello all or should I say ahoy shipmates, have a look at the spray rails fitted on my ship, the reason I added these was to eliminate or greatly reduce the spray that one gets in the face if one is motoring flat knacker, without the rails I would get...
