Furler Support while trailering
Published date: December 5, 2009
  • Boat Type: Boat Type
After driving about 500 miles with my boat hook pole straining to hold up my furler, I came up with this furler support boom. Cost $0. I used pvc and joint epoxy materials left over from building my house. I can put the support into the tow beast while on the water!
Published by: Doug W
Model Year: 2010
Photo Caption: PVC boom
PVC boom supporting the furler
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Quasi Mac 33
    Quasi Mac 33
    Miscellaneous - - January 1, 2009
    I thought I would post my ideas here as I do not have a picture hosting site. I moved the head forward as Duane wants it and fitted a nav station starboard aft of the table. Although, they could be swapped for a large head and small nav. The table is...
