Furler support for trailering
Published date: January 20, 2010
  • Boat Type: Boat Type
I made this simple support for the furler from scrap steel. It mounts off the bolts (slightly longer ones required) that go through the bottom of the mast and the mast/pulpit rail fitting used when trailering. It also prevents the mast from trying to rotate from side to side. It can be fitted or removed in seconds.
Published by: Buell_S1W
Model Year: 2009
Photo Caption: Furler support
Furler support fitted
Furler support close up
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Christmas Mod
    Christmas Mod
    Miscellaneous - - December 7, 2009
    I understand this is not your typical "mod", but I thought I would share it with you anyway in hopes of promoting "Mac Pride" (NOT McPride....no infringement lawsuits please.) Here are a couple of gift ideas you can use this Holiday Season. The beaut...
