Cockpit and motorwell drain plumbing
Published date: February 5, 2010
  • Boat Type: Boat Type
I replaced the original clear plastic tubing that provided drainage for the cockpit and motorwell. I used sched 40 PVC, and ran it as close to the walls as possible to get it up and out of the way. I also connected the discharge of my bilge pump to it. You can see the bilge pump and fishfinder transducer mounted in the lowest spot.
Published by: Doug91mac26s
Model Year: 1991
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Furler support for trailering
    Miscellaneous - - January 20, 2010
    I made this simple support for the furler from scrap steel. It mounts off the bolts (slightly longer ones required) that go through the bottom of the mast and the mast/pulpit rail fitting used when trailering. It also prevents the mast from trying to...
