Inexpensive/Easy Laz Floor
Published date: February 9, 2010
  • Boat Type: Boat Type
When I first got my boat I really didn't like putting stuff in the laz right on the bottom of the hull. I have since replaced this with a wood floor, but it did work pretty good. I thought I'd pass it on, in case anyone might be interested. It's real easy and inexpensive to make. I made it out of sched 40 PVC, in two sections, so it could be removed through the hatch if required. All the pieces were dry fitted together, no glue was used. The cross pieces were just slipped over and could be moved to give the best spacing, hopefully you can tell what I mean by looking at the pictures. This really makes a quite strong support system. I put my anchor & rode in there inside a crate, barbecue, buckets, and a whole lot of other stuff.
Published by: Doug91mac26s
Model Year: 1991
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Cockpit and motorwell drain plumbing
    Miscellaneous - - February 5, 2010
    I replaced the original clear plastic tubing that provided drainage for the cockpit and motorwell. I used sched 40 PVC, and ran it as close to the walls as possible to get it up and out of the way. I also connected the discharge of my bilge pump to i...
