Trailer mod - double axis for European on-road use
Published date: February 26, 2010
  • Boat Type: Boat Type
US trailer is not allowed to be used in EU countries for on-road purposes. Anyway, one axle trailer without brakes is not very safe for trailering, I modified it and then (with support of local trailers producer) certified for on-road use.
I put 2 axles + brake from KNOTT (both special for boat trailers), 4 pcs of 13inch wheels and I made completely new electrical installation with removable rear panel for lights and registration plate.
I used zinc, inox an aluminium materials only.
Then I made some other small improvements, because the original quality is not very good.
Only missing mod is to fix spare wheel somewhere and change the small front wheel, which is very poor in stock version :-)
Published by: Hovez
Model Year: 2009
Share
Related Mods
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
  • Beefed up jockey wheel for trailer
    Trailer - - January 7, 2010
    The very lightweight jockey wheel system on my trailer soon broke so I made up a heavy duty system using a solid rubber 10 inch wheel instead of the factory plastic cookie sized one. The bigger diameter wheel rolls & steers a lot easier & has ball be...
  • easy trailer hooking
    Trailer - - July 31, 2009
    For easy coupling the trailer to the car alone i have a truck mirror bolted to the ladder with wingnuts so i can see where i am backing so i easy hitting the trailer in first try ... Use some pieces of steeltubes and flatbars for making the mirrorarm...
