Rewiring
- Boat Type: Boat Type
This shows a conduit above the galley on the port side which is used for bringing wires from the upper to the lower parts of the boat, or vice-versa. My first guess was to drill hole (A) which is a two-inch hole. I soon found that the center drill guide part, which sticks out past the hole saw part, drilled into some kind of support running down the center of the conduit. Oooppss! No problem - just cover it with a blank white plastic cover. It was an important lesson though, as it allowed me to figure out what it was like inside the conduit.
The support runs through the center, but doesn't reach all the way to the edges or to the bottom. So you want to drill your holes close along the sides or bottom. Doing this, you shouldn't hit anything. Next I drilled one-inch holes (B) near the top along the side, and in the center along the bottom. These I use to guide all the neccessary wires: main battery power to front panel, bow light to front panel, VHF antenna to ceiling to through-hull, etc.
Published by: Heath
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
