Propeller Guard
Published date: March 1, 2010
  • Boat Type: Boat Type
My original rudder had some huge gouges in it from the prop hitting it. That was the main reason I installed this prop guard, to protect my new Idasailer HDPE rudder. Some people make these out of a strip of aluminum or stainless, this one is made out of a tough plastic.
Published by: Doug91mac26s
Model Year: 1991
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Inexpensive/Easy Laz Floor
    Miscellaneous - - February 9, 2010
    When I first got my boat I really didn't like putting stuff in the laz right on the bottom of the hull. I have since replaced this with a wood floor, but it did work pretty good. I thought I'd pass it on, in case anyone might be interested. It's real...
