Seasonal Bearing Maintenance
Published date: March 8, 2010
  • Boat Type: Boat Type
This is more work I've done to my trailer, rather than a mod. But thought I would share the pic's and a link in case anyone wanted some info regarding wheel bearings, races or brake shoes. When I brokedown, inspected and rebuilt my hubs all the existing parts passed inspection with flying colors. I am going to keep a new set of bearings and seals in case I run into problems during our two trips this summer. I also plan on doing this every spring.
Here is an excellent link:
http://www.championtrailers.com/techsup.html#bleed_brakes
Regards
Mike
Just Nuisance
Published by: Just Nuisance
Model Year: 2001
Photo Caption: 10
Share
Related Mods
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
  • Trailer mod - double axis for European on-road use
    Trailer - - February 26, 2010
    US trailer is not allowed to be used in EU countries for on-road purposes. Anyway, one axle trailer without brakes is not very safe for trailering, I modified it and then (with support of local trailers producer) certified for on-road use. I put 2 ax...
  • Beefed up jockey wheel for trailer
    Trailer - - January 7, 2010
    The very lightweight jockey wheel system on my trailer soon broke so I made up a heavy duty system using a solid rubber 10 inch wheel instead of the factory plastic cookie sized one. The bigger diameter wheel rolls & steers a lot easier & has ball be...
