Bow light
Published date: November 30, -0001
  • Boat Type: Boat Type
Here is a picture of a Jabsco floodlight I installed on the bow railing. WHen comeing back to the slip after dark, there were some unlighted obstacles that I wanted to avoid hitting. Putting the light up there avoids all reflection off sails and chrome. The light has seen 2 or 3 seasons of use now with no problems, but it gets a lot of salt spray up there. I keep thinking of moving it to the mast, but then will get reflected light killing night vision. I guess it is OK up front.
Published by: Craig LaForce
Model Year: 2004
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
