Water fill
Published date: March 31, 2010
  • Boat Type: Boat Type
I've seen several different water fill systems on our boats. This is how I did mine several years ago on my 99X. The system looks factory made . I put a 10 gal. ridged tank under the forward V berth. I secured it with tiedown straps and repacked all the foam. It is very convenient and looks great.
Published by: capncarp
Model Year: 1999
Photo Caption: Water Fill
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
