Delta Plow Anchor
Published date: April 2, 2010
  • Boat Type: Boat Type
Used 4" PVC to create sheath to hold a 22 lb Delta plow anchor.
Published by: mdeane
Model Year: 2005
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Anchor Roller and Anchor Upgrade
    Anchoring - - February 23, 2010
    Anchor and roller upgrade to Lewmar anchor roller and Fortress FX16 anchor I was compelled to upgrade to larger anchors after several daytime and overnight dragging episodes. The Mac 26M is a light boat with a lot of wind surface above the waterline....
  • Stern anchor
    Stern anchor
    Anchoring - - August 24, 2009
    This "tube mount" puts a reasonable-sized stern anchor in easy reach from the helm. I'm using a Fortress FX-11 in mine, which is close in size to a 13-lb Danforth. Other-style anchors with similar-sized stocks would probably fit as well. I used 3-inc...
