New forestay stem fitting
Published date: April 22, 2010
  • Boat Type: Boat Type
We replaced the "cheesy" front chainplate with this new stem fitting. Now the very front deck area is clear for a bow roller and hawse pipe (future mod and pictures) and it is much stronger (a split back stay was also installed). A piece of 3/16 x 1 ss stock was drilled and formed. The edge of the bow was reshaped with West Systems epoxy to make a flush surface for the new fitting and give it a clean look.
Published by: THE CUSCUS
Model Year: 1979
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Topping Lift
    Topping Lift
    Rigging - - April 19, 2010
    This very neat solution for the Topping Lift, I got from the net (http://www.frankhagan.com/weekender/toplift.htm). The Bug was previously used as a trailer-sailer so the Topping Lift was probably never used. It came as a basic line from the top of t...
  • Stack-Pack and Lazy Jacks
    As we're keeping the Bug on the water, I didn't want to have to pack the main away after every trip. The boat came with a never-used Stack-Pack. This consists of a the sail bag with fittings for Lazy-Jacks and battons - the latter being 2 pieces of e...
