Bilge Pump
Published date: May 1, 2010
  • Boat Type: Boat Type
When we bought Just Nuisance there was an uninstalled bilge pump. I bought an above waterline thru hull from West Marine and some plumbing supplies from Home Depot. When the bilge is not in use the safety valve is closed preventing any water from back feeding into the bilge. I added the electrical panel for a previous mod which came in handy for the bilge.
Regards
Mike
Just Nuisance
Published by: Just Nuisance
Model Year: 2001
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Propeller Guard
    Propeller Guard
    Miscellaneous - - March 1, 2010
    My original rudder had some huge gouges in it from the prop hitting it. That was the main reason I installed this prop guard, to protect my new Idasailer HDPE rudder. Some people make these out of a strip of aluminum or stainless, this one is made ou...
