lighting mods
Published date: June 20, 2010
  • Boat Type: Boat Type
I'm changing the incandescents to fluros. The long one I bought on a holiday in Vietnam. It is rechargeable. I couldn't get wires over the table.
The little ones are 16 watts. The white between the light and the headlining is a piece of acrylic to hide the original holes.
The one over the galley is wired back to the switchboard. It took me 2 hours to feed the wire the 600mm between the board and the light.
Published by: dlymn
Model Year: 2007
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
