Compass in Cockpit
Published date: December 1, 2019
  • Boat Type: Boat Type
I have added a compass in the cockpit. The only thing to watch out for is when you are drilling the hole in the bulkhead, make sure that when you insert the compass, it does not hit the sides of the access compartment behind the bulkhead.
The line you see to the left is the jib furling line.
Published by: Heath
Model Year: 1997
Share
Related Mods
  • VHF Radio, Hooks
    VHF Radio, Hooks
    Instruments - - December 1, 2019
    (A) shows the VHF radio we had installed. The guy doing the installation ran into the lower-upper liner problem and decided to just run the power lines outside the wall for a short distance from the upper liner and then into the side of the house bat...
  • VHF Antenna
    VHF Antenna
    The VHF antenna cable (B) passes through the deck near the mast base. When you drill you hole for the cable, you have to watch for two things: * Make sure that you drill far enough to the side so that you do not hit the metal backing plate (A). * Mak...
  • VHF Antenna
    VHF Antenna
    This shows where the antenna cable exits the deck. It comes out right next to the conterboard cable without rubbing against it. This end connects with the antenna cable exiting the mast on the same side. To get the coaxial antenna cable to come out t...
