Pop-up Top Gas Lift
Published date: July 9, 2010
  • Boat Type: Boat Type
I read where someone had installed gas shocks to the pop up canopy on a V22. After working on my boat the first week I owned it, that pop-top got heavy and I kept dropping the prop rods. I made a trip to Pep Boys auto parts and found they had a huge selection of gas lift rods so I bought two identical units as close to 24" I could find - I ended up with 22" fully extended. The modification was much easier to do than I anticipated and it makes life so much better when lifting the top. It stays up great and it stays down great with no need to prop it with sticks or hold it down. Gravity does the trick once it is pushed about half way and the gas lifts do the work after you get it started up.
The only tricky part is making sure the rod is fully extended where you want the top to open fully (use the sticks to mark this location), and make sure the top will close all the way before the gas strut bottoms out. Most SUV rear hatch gas struts provide more than enough lifting force to hold up the MAC pop top canopy. After installing one of my gas struts, the top would just stay up by itself. Two struts did the trick and held it up tightly.
Published by: cookwithgas
Model Year: 1977
Share
Related Mods
  • Front Speakers
    Front Speakers
    Interior - - December 1, 2019
    We installed speakers in the vertical surfaces just above the v-berth. I would advise some caution when cutting the fiberglass as it is quite thin. Be sure to put the styrofoam back up in behind the speakers for floatation and to avoid the speakers s...
  • Communications/entertainment
    Greetings from Melbourne, Australia! I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X. A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical s...
