Winch Pull adjuster
Published date: September 19, 2010
  • Boat Type: Boat Type
I never liked the winch placement because the "pull" was down as the bow came forward on the trailer. One day I found this roller and got an idea. I got some scrap metal and a large bolt. Adding the roller just below the Vee bumper changes the "pull" to up. On steep ramps that used to cause the greatest gap and the hardest "Macgregor bump" the bump is practically eliminated. Now I can pull the bow far enough forward that as the boat settles when trailered up the ramp it is still snug on the Vee bumper.
Published by: Retcoastie
Model Year: 2002
Photo Caption: Roller and bolt
Roller in position
Roller ready to use
Share
Related Mods
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
  • Taking my V25 off the trailer
    Trailer - - September 10, 2010
    These pictures show how I took my boat off it's trailer, so I could safely work on it. Take a 2x12, hold it up against the bottom of the transom and trace the curvature of the bottom (make 2 of these then screw together to make a 4x12). Use some 24x2...
  • Trailer Roller
    Trailer Roller
    Trailer - - July 15, 2010
    I removed three of the center rollers off of my old speed boat's trailer. Using 2" aluminum box tubing, I fashioned a cross member. I made spacers out of steel pipe to prevent the tubing from collapsing as I crank the steel bolts tight. I added the f...
