Rudder Linkage
Published date: January 19, 2011
  • Boat Type: Boat Type
Never liked the idea that the two rudders where tied together by a bolt through a 1" pipe with no bearing surface or adjustment. Picked up a couple of Tie Rod End Bearings from northern tool - "http://www.northerntool.com/shop/tools/product_23631_23631" and made the fittings by cutting up some 3/8" SS bolts to attach to the end of the 1" pipe between the rudders. The welds did no come out exactly square (I did not do the welding but probably could not have done better anyway) but that just made drilling the holes in the pipe more challenging. Just finished the installation and so far so good after a quick spin around the harbor it is very smooth and responsive.
Published by: markh1f
Model Year: 2009
Photo Caption: before the welding
Welded up and ready to install
Installed
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Bilge Pump
    Bilge Pump
    Miscellaneous - - May 1, 2010
    When we bought Just Nuisance there was an uninstalled bilge pump. I bought an above waterline thru hull from West Marine and some plumbing supplies from Home Depot. When the bilge is not in use the safety valve is closed preventing any water from bac...
