Bow Roller
Published date: January 24, 2011
  • Boat Type: Boat Type
I liked the BWY bow roller, but I wanted something that extended to cover the fore stay tang for added strength. The geometry of the tang would try to slice the foredeck if that little bracket around it gave way. I made a template out of cardboard then bought some 14g SS sheet stock. Cut is with a band saw filed it smooth and bent it with a finger break. The Delrin roller is from WM. I also cut out a similar backing plate, some 1/4 - 20 SS machine screws with lock nuts and a few dab of 5200. It is still a pain to reach that far forward through the V birth. The fore stay tensioner helps keep the rigging nice and tight.
Published by: Capt Capsize
Model Year: 1997
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • BOW ROLLER/ANCHOR RODE LOCKER
    Anchoring - - July 13, 2010
    This is my anchor and rode storage arrangement. I was originally going to attach a piece of 1-1/2" PVC pipe to the reducer at the top, to get the rode into the bilge area of the bow, but it was to difficult to feed the rope part of the rode down that...
  • Delta Plow Anchor
    Delta Plow Anchor
    Anchoring - - April 2, 2010
    Used 4" PVC to create sheath to hold a 22 lb Delta plow anchor. Published by: mdeane
