Anchor Roller and Bow Plate
Published date: February 2, 2011
  • Boat Type: Boat Type
Never liked the factory anchor roller and there is no such thing as "too much anchor". However, on more than one occassion in the middle of the night at an anchorage off the intracoastal waterway in Georgia, I have had boats drift by me, within feet of my bow because they had "too little anchor". We fabricated a deck plate out of 1/4 inch stainless steel, sanded and polished it for what seemed like days to get a high gloss. We ordered a heavy duty plow anchor style bow roller from Defender Marine as well as a 25lb Manson Supreme Anchor with 200 feet of anchor rode and 40 feet of chain. We also went underneath the front deck and put a 1/4 inch stainless steel backing plate. It was alot of fun getting the holes marked while lying on your back shoved as far into the forward V area as you can get, holding a 10 lb steel plate right over your face while the Wife marked the holes. That was just marking the holes, tightening the lock nuts up was even more fun. The Anchor Roller is big and needs to be fitted for placement while the roller furler is attached if possible. I wanted to make sure I had clearence. It fits perfectly, anything taller in regards to the anchor roller and it would not work. We also mounted the new cleats through both plates of steel. If something breaks off up there the bow is going with it.
Published by: streuber
Model Year: 2007
Photo Caption: Anchor Underway
Fitting the Anchor for Plate Design
Looking Down on Anchor
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Bow Roller
    Bow Roller
    Anchoring - - January 24, 2011
    I liked the BWY bow roller, but I wanted something that extended to cover the fore stay tang for added strength. The geometry of the tang would try to slice the foredeck if that little bracket around it gave way. I made a template out of cardboard th...
  • BOW ROLLER/ANCHOR RODE LOCKER
    Anchoring - - July 13, 2010
    This is my anchor and rode storage arrangement. I was originally going to attach a piece of 1-1/2" PVC pipe to the reducer at the top, to get the rode into the bilge area of the bow, but it was to difficult to feed the rope part of the rode down that...
