venture 17 manual needed
Published date: April 24, 2011
  • Boat Type: Boat Type
i recently purchased a used, i think 1996, Venture 17. It does not have a manual, a boom, or a rudder. Are those available for purchase somewhere? A newby, all help appreciated.
Published by: datamarc
Model Year: 1996
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • KEEL RECONDITIONING part I
    Miscellaneous - - April 18, 2011
    I just finished refurbishing the keel on my 1979 V25. Started by having the keel sandblasted by a local shop (charged me $60.00). I made a chain sling, using large shackles on the ends, to make moving it around easy (see picture). Next step, as soon ...
