Head Door Handle
Published date: December 1, 2019
  • Boat Type: Boat Type
This is an easy one that makes a big difference. Our boat came from the factory without a handle on the head door. In order to close it you had to grab the little latch.
I installed a nice little wooden handle on the inside of the head door so that it is easy to close the door from the inside. I drilled a hole and put a screw right through the door from the other side.
Published by: Heath
Model Year: 1997
Share
Related Mods
  • Head bifold/vberth door
    Interior - Head (MacGregor 26M) - June 27, 2020
    To add legroom in the head, I created a bifold door panel which I added to the main door on the inside out of 6mm marine ply I had left from another project. I used 3/4 wrap around hinge, which I installed backwards since both the main door and the e...
  • Front Speakers
    Front Speakers
    Interior - - December 1, 2019
    We installed speakers in the vertical surfaces just above the v-berth. I would advise some caution when cutting the fiberglass as it is quite thin. Be sure to put the styrofoam back up in behind the speakers for floatation and to avoid the speakers s...
  • Communications/entertainment
    Greetings from Melbourne, Australia! I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X. A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical s...
