MSD Head w/Deck Pumpout
Published date: July 3, 2011
  • Boat Type: Boat Type
Stainless steel deck pump out and vent. The pump out fitting requires a 1-3/4" hole, and the deck is plywood cored.
For the pump out fitting, I first drilled a 2" hole through the deck, but not through the inside liner. Then I re-inserted the plug and filled the space around the plug with Marinetex, then drilled a 1-3/4" hole all the way through the inside liner, so the wood core is sealed from moisture.
I also drilled over-sized holes for the screws, filled with Marinetex, then re-drilled screw holes, sealing the wood core. The vent hole has no wood, and the rubber gasket provides a good seal.
The hoses are connected to the five gallon holding tank.
Using a MSD porta-pottie still allows manual dumping of the holding tank should a pump out facility not be available.
I used a sink drain wall pipe from Home Depot to provide an elbow connection for the large pump out hose to the holding tank. For the small vent connection, I used an elbow fitting for a washing machine hose. I had to use the elbow connectors to make the turn I needed under the cabinet. Both are easily disconnected for manual dumping.
The hoses run up through the cabinet, and out the top. The cabinet does a good job of hiding the hoses.
http://s33.photobucket.com/albums/d64/doug91mac26s/Head/
Published by: Doug91mac26s
Model Year: 1991
Share
Related Mods
  • Self-Closing Head Door
    Head - - December 1, 2019
    Want to solve a real irritating situation, especially for those of the female persuasion? The head door flops around as it is, and trying to lock it from the inside when the boat is under sail or power can be a real pain. We put the self-closing hing...
  • Converting Rope Locker to a Head
    Head - - April 30, 2011
    As promised here is the update on installing an AirHead Composting Head http://www.airheadtoilet.com in an X. Pretty straight forward, attached to the floor (sole?) of the head with provided hardware and vented to a previously installed solar vent th...
  • Head pump out arrangement
    Head - - December 18, 2010
    We have a porta potti allowing for a pump-out connection. Installed an appropriate pump-out hose, an external suction fitting and a vent. The hose of the vent line is overkill; a pressure hose is not needed, since this line is to allow air in to enab...
