Rudder Torque Tube Bushing
Published date: July 7, 2011
  • Boat Type: Boat Type
In my 26M, the steering linkage has always been a bit sloppy. When investigating, I noticed the fiberglass towers which hold the tops of the rudder torque tubes were quite worn. I suspect that was from the factories oversized hole and a few years of the rudders clacking back and forth. The starboard side had nearly 3/16 inch of play while the port side was just over an 1/8 inch.
To remedy the situation, I ground down the fiberglass towers and fashioned a few precision (friction tight) fitting bushings from delrin (Polyoxymethylene). I purchased two 2.5" square blocks 3/4" thick from Taps Plastics. I fixed up a batch of epoxy resin with flox to make a structural pad to level the fiberglass rudder towers and surround the delrin. Since nothing really bonds to delrin, I had to encase them into the tops of the rudder towers, and the final step was to fiberglass over them with cloth and resin.
This mod is great, the rudder torque tube are friction tight. They don't move up, down, or left, right unless you exert a mild force on them. In addition to removing slack from the steering, and quieting yet another "clunk" while sleeping in the berth this mod makes the boat a little more water tight.
Chris.
Published by: u12fly
Model Year: 2006
Photo Caption: You can see the gap between the fiberglass tower and the rudder torque tube
Here you see the resin flox leveling pad which helps encase the delrin
Final step is to cover the assembly with fiberglass and epoxy resin
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • venture 17 manual needed
    Miscellaneous - - April 24, 2011
    i recently purchased a used, i think 1996, Venture 17. It does not have a manual, a boom, or a rudder. Are those available for purchase somewhere? A newby, all help appreciated. Published by: datamarc
