Poor man's traveler
Published date: July 11, 2011
  • Boat Type: Boat Type
I have tried to figure out where to mount a traveler that would work with the existing end boom sheeting, and with my bimini installed. I have come up with this, makeshift main sheet set up, and it seems to perform really well to windward! And best of all, it was completely free, just re-arrange the existing lines!
If you re-route the line from the block at the end of the boom to the windward side of the boat (pass the line under the tiller) and wrap it around the mooring cleat, when you sheet in the main, all the force is directed to the windward side of the boat. This holds the boom well past the mid point of the boat and get you that extra couple of degrees to windward!!
Cheers!
Happy sailing.
Published by: shawndutchcanadian
Model Year: 1976
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • SPINNAKER HALYARD HOUND
    Rigging - - June 6, 2011
    These are pics of the hound that I attach my spinnaker halyard block to. Its a piece that is commonly used on bigger boats, but it is a nice clean way to do it. A 1/2" wide slot is cut in the mast, about 4" long, and the 2 halves of the bracket are i...
  • No more Mac Dance with lifelines that go slack
    Rigging - - April 3, 2011
    The stock lifelines run from the bow pulpit and terminate in an eye at the cockpit forward stanchions. The cockpit lifelines run from a fitting on the stern up through the aft stanchion to a snap shackle which clips to this eye and creates a running ...
