Rudder Deployment Lines Entering Hull
Published date: July 13, 2011
  • Boat Type: Boat Type
Every now and then I noticed things on my sailboats that seem a bit unfinished to me, and one in particular was the simple hole drilled in the aft hull of the boat for the rudder deployment ropes. This area also happens to be another source of water getting into the boat.
After running across some plastic feed through fairleads I decided to build up the structure to make a more elegant bump and at the same time make it a little bit harder for rain water to seep into the hull. I counter bored the original holes such that the bottom would be square and made up a model of the part to build a mold around. The structural part is made of epoxy and flox, I later over molded that with light weight body filler so I could grind and sand the bumps into a smoothly flowing shapes.
After completing the basic shape I primer painted the area to get a feel of the final product before adding finish filler and making a final sand. The bumps were painted when I shot the top section of the boat a few months ago, but I just now glued in the plastic feed though and can see the completed fruits of my labor.
Chris.
Published by: u12fly
Model Year: 2006
Photo Caption: Building up the bumps on the aft hull of the boat
The painted and finished nodule blends nicely into the boat hull
The port side nodule after finish paint and polish
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Rudder Torque Tube Bushing
    Miscellaneous - - July 7, 2011
    In my 26M, the steering linkage has always been a bit sloppy. When investigating, I noticed the fiberglass towers which hold the tops of the rudder torque tubes were quite worn. I suspect that was from the factories oversized hole and a few years of ...
