Boom-less Main Sail
- Boat Type: Boat Type
I liked the Boom-less sail on the F22 Tri I had purchased plans for so I contacted a Sail-Maker and was able to convert my Main sail into a dual purpose sail. So I can now use it with or without the boom. It makes it easier to set up and nicer in the cockpit without the boom.
Published by: flyboy26m
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
Poor man's travelerRigging - - July 11, 2011
I have tried to figure out where to mount a traveler that would work with the existing end boom sheeting, and with my bimini installed. I have come up with this, makeshift main sheet set up, and it seems to perform really well to windward! And best o...
SPINNAKER HALYARD HOUNDRigging - - June 6, 2011
These are pics of the hound that I attach my spinnaker halyard block to. Its a piece that is commonly used on bigger boats, but it is a nice clean way to do it. A 1/2" wide slot is cut in the mast, about 4" long, and the 2 halves of the bracket are i...
