Natures Head
- Boat Type: Boat Type
I did not like the Port-a- potty in the M26 anymore than in my RV. After a year of looking around I found a product called Natures Head -A composting, liquid separating head.. The installation was straight forward and took only a few hours to complete. I wired the electrical into the lead going into the Head light fixture and ran the Vent pipe through the cabin top window into a mushroom vent. I have used it on a four day trip and am very satisfied. No smells and you empty the compost every 60 uses (no smell). The liquid bottle was half full so I should get a week out of it. I purchased a second bottle for longer trips.
Published by: flyboy26m
Related Mods
Self-Closing Head DoorHead - - December 1, 2019
Want to solve a real irritating situation, especially for those of the female persuasion? The head door flops around as it is, and trying to lock it from the inside when the boat is under sail or power can be a real pain. We put the self-closing hing...
MSD Head w/Deck PumpoutHead - - July 3, 2011
Stainless steel deck pump out and vent. The pump out fitting requires a 1-3/4" hole, and the deck is plywood cored. For the pump out fitting, I first drilled a 2" hole through the deck, but not through the inside liner. Then I re-inserted the plug an...
Converting Rope Locker to a HeadHead - - April 30, 2011
As promised here is the update on installing an AirHead Composting Head http://www.airheadtoilet.com in an X. Pretty straight forward, attached to the floor (sole?) of the head with provided hardware and vented to a previously installed solar vent th...
