Thru-hull custom wrench
Published date: July 25, 2011
  • Boat Type: Boat Type
I searched for about a week to find a small, short 1-3/4" wrench which I could use to install and tighten a 1" thru-hull plastic fitting. I never did find anything acceptable, so I decided to fabricate one. This was made out of scrap oak I had laying in my burn pile. I ran it through the table saw a few times before clamping it into the old turret mill. I later stained and varnished the wrench and added it to my tool box.
Published by: u12fly
Model Year: 2006
Photo Caption: This is the wrench after cutting the handle shape and a little sanding
Here is the retangular blank after making the hex cuts with a turret mill
Here is the wrench in action
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
