BWY Backstay Tensioner
- Boat Type: Boat Type
Replaced the factory backstay with a new Backstay Tensioner from Blue Water Yachts. Makes pinning the CDI RF easy, just loosen the backstay and raise with the mast raising winch (I have the new style). The RF easily lines up with the forestay tang hole without any fighting or downward pressure. Can be done by one person.
Published by: henecle
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
Mac 19 Halyard set upRigging - - August 23, 2011
Time to add some Mac 19 life to the Mods section... Added two Harken 140s at the base Port and Starboard to allow for easier halyard handeling of the Mainsail and the Crusing Asymm from the cockpit. As an added precaution, I cleat them each off to a ...
Boom-less Main SailRigging - - July 14, 2011
I liked the Boom-less sail on the F22 Tri I had purchased plans for so I contacted a Sail-Maker and was able to convert my Main sail into a dual purpose sail. So I can now use it with or without the boom. It makes it easier to set up and nicer in the...
