Mast Raising System
- Boat Type: Boat Type
Added the new style mast raising winch to my Mac 19... makes the process of raising and lowering the mast by one person very easy. Also swapped out the 3/8 inch bolt for the BWY Quick Rig mast base pin to make installing and removing the winch faster.
Published by: henecle
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
BWY Backstay TensionerRigging - - August 23, 2011
Replaced the factory backstay with a new Backstay Tensioner from Blue Water Yachts. Makes pinning the CDI RF easy, just loosen the backstay and raise with the mast raising winch (I have the new style). The RF easily lines up with the forestay tang ho...
Mac 19 Halyard set upRigging - - August 23, 2011
Time to add some Mac 19 life to the Mods section... Added two Harken 140s at the base Port and Starboard to allow for easier halyard handeling of the Mainsail and the Crusing Asymm from the cockpit. As an added precaution, I cleat them each off to a ...
