Anchor Lights
Published date: August 26, 2011
  • Boat Type: Boat Type
Simple and straightforward, and heavily borrowed upon from Tahoe Jack
http://www.macgregorsailors.com/modt/index.php?view=553
Includes the Windex and 3db Antenna, however I use the Aqua Signal light mounted on a short piece of PVC pipe due to LED availability at time of purchase. Also, unlike most Mac owners, I use Military Grade D38999 Connectors for my mast connections. 5 circuits, 6 really because the shell is the GND return. Any commercial grade connectors I purchased ALWAYS rotted way. The shell is waterproof and the pins are gold plated. One of the perks working at a Military Contractor.
Disclaimer:
ALWAYS check the documentation that comes with the equipment you purchase for installations, minimum wire Gauges, etc. Following any advice here is done entirely at your own risk, with no liability to this site, the site owner, or to the poster of that information.
Suggested Sources
LED Light: Navigation Light 44 mm Barrel End Festoon, MFR: Cruising Solutions
Anchor Light Housing: Series 25 All-Round / Anchor Light, P/N: 25000-7, MFR: Aqua Signal, Vendor: Defender #700015
Published by: Laika 26X
Model Year: 2002
Photo Caption: Mast Schematic
Anchor Light Assembly
Mast Wiring Connectors
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
