Forward Hatch Adjuster
Published date: August 28, 2011
  • Boat Type: Boat Type
Any old stick can be used to prop open the forward hatch, but I prefer something more integral. Simple enough to install so I'll save you folks one of my long drawn out speeches here. It does add, IMHO, a nice touch to the boat.
Disclaimer:
Following any advice here is done entirely at your own risk, with no liability to this site, the site owner, or to the poster of that information.
Hatch Adjuster: Telescoping Hatch Adjuster, Vendor: West Marine #10287712
Published by: Laika 26X
Model Year: 2002
Photo Caption: Installed Hatch Adjuster
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Rudder Deployment Lines Entering Hull
    Miscellaneous - - July 13, 2011
    Every now and then I noticed things on my sailboats that seem a bit unfinished to me, and one in particular was the simple hole drilled in the aft hull of the boat for the rudder deployment ropes. This area also happens to be another source of water ...
