Access to the aft floatation area
Published date: August 30, 2011
  • Boat Type: Boat Type
Back in 2009, shortly after purchasing our 26M, I took the boat down for an 18 month period of modifications. This was one of the first modifications I started on the boat... but one of the last completed. I needed to gain access to the aft floatation area in order to install the hot and cold water lines and fuel lines which transition through this area and I wanted to mount my stern rail seats without cutting access holes in the outside of the boat.
This was the first "hole" I cut in the boat, and because of the odd shape I decided to use tape as my straight edge marking the cut lines. The opening must be made large enough to remove the foam flotation blocks housed in this area, which are up to 12x12x6 inches in size. Fiberglass is most easily cut using a small cutting disk on a Dermel tool. I suggest safety goggles and dust mask when working in such a tight area. Also keep the thickness of your cut shallow since there are probably electrical wires in this area that you won't want to damage.
Once the center piece of fiberglass is removed you will see the Styrofoam blocks packed into this area. They will most likely stay put, held in place by friction. They are easily removed as long as your opening is large enough. I placed all the pieces from the right cavity in a bag separate from the left so I could later restore all the foam that was originally there.
Having this area open was the only way to successfully complete some of the other modifications I have posted, or will be posting. At the completion of those modifications I was originally planning to place the fiberglass pieces back in, after making attachment brackets for them, however I used the material to fill in the area under my sliding galley (see my modification posting on the sliding galley) . Instead I fabricated covers out of 1/4" birch plywood which could simply be screwed in place. Whatever you do does not really mater since this area is simply not visible once the rest of the boat is put back together.
Chris.
Published by: u12fly
Model Year: 2006
Photo Caption: The largest area possible is marked using tape as a guide
The foam blocks are held in place with friction but are easily removed
A removable wood panel finishes the area and allows for easy access later
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Forward Hatch Adjuster
    Miscellaneous - - August 28, 2011
    Any old stick can be used to prop open the forward hatch, but I prefer something more integral. Simple enough to install so I'll save you folks one of my long drawn out speeches here. It does add, IMHO, a nice touch to the boat. Disclaimer: Following...
