Quick Rig Mast Raising system
- Boat Type: Boat Type
Added a mast bail at the connection point for the baby stays used to support the mast while raising. Got it from APS in Annapolis, MD. Then fitted two SS snaps to each end of the mast raising winch lines to allow for quick connects and a screw shackle to the bow cleat for final connection. Seems to work well so far.
Published by: henecle
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
Turnbuckle BootsRigging - - September 2, 2011
After one mast raising incident involving a bent stay adjuster, I went out and purchased these Davis Instruments Turnbuckle Boots. They keep the stay adjuster straight and aligned when I raise the mast. They lift easily as well to inspect the ring di...
Halyard J HookRigging - - September 2, 2011
You can secure your halyards any number of ways. From merely wrapping them around the outside of your upper shrouds, to bungee cords, to simply tying off with a spare line. But if you read my mods you know I prefer a more integral, purpose built meth...
