Spray rail modification
Published date: September 28, 2011
  • Boat Type: Boat Type
Hello all or should I say ahoy shipmates, have a look at the spray rails fitted on my ship, the reason I added these was to eliminate or greatly reduce the spray that one gets in the face if one is motoring flat knacker, without the rails I would get a face full of spray if I ventured past say five degree's of head wind on the bow, now with the spray rails I don't get spray until I'm at 45 degree's to the wind and then its only an occasional sprinkle
So the long and short of it is, 98% spray reduction, well worth it for those fast trips to pick up the bubbly for the admiral.
Have a look at the following UTUBE video.
http://www.youtube.com/watch?v=dORyeg4JIV4
Published by: CPT Haddock
Model Year: 2005
Photo Caption: Spray rail modification
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Access to the aft floatation area
    Miscellaneous - - August 30, 2011
    Back in 2009, shortly after purchasing our 26M, I took the boat down for an 18 month period of modifications. This was one of the first modifications I started on the boat... but one of the last completed. I needed to gain access to the aft floatatio...
