Solar Panel Wired Through Pole
- Boat Type: Boat Type
I've been getting mod ideas from this forum since I got my 26X a year ago and combined a few ideas to come up with this solar panel mod. I went with a 30 watt flexible HQRP solar panel, used a spiral shaver cord and send the wiring through the grab bar on the port side of the boat. This way no wiring can be seen inside. In the battery box the wiring runs to a Sunforce 7 Amp Charge Controller which keeps the batteries topped up but not overcharged. The controller can accommodate a second panel (and up to 105 watts) if I decide to double the solar charging capacity in the future.
Published by: brishel001
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
