engine link to rudders
Published date: January 12, 2012
  • Boat Type: Boat Type
This mod intends to facilitate the engine connection and disconnection from the rudder link as well as ensuring the rudders are aligned with the engine. It is replacing the stock solution with one that does not require any tools to couple and decouple the engine from the rudders. It is made out of a 1/2 tube 1/16 wall thick and 2 rod end bearings, a male and a female - 3/8 24 threads.
The male end is inserted and epoxy glued in the tube. For the female, I cut the end of a 3/8 stainless steel 24 threads screw, inserted and epoxy glued it at the other end of the tube while exposing ~ 1 1/4 of the thread. Based on how much the female rod end is screwed we can control the overall length of the link and the alignment of the rudders with the engine. The female attaches to either the fixed point, keeps the engine straight and disconnected from the rudders while sailing, or to the rudder arm when the engine needs to be used.
Published by: Calin
Model Year: 2006
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Gas Tanks - Installation & Draining
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • Internal Bow Fuel Tank
    Motor - - January 8, 2012
    Added a Moeller 19 Gallon internal Bow Fuel Tank. 1. Cut really big hole (save piece) 2. Remove Foam 3. Fiberglass wood piece on top of ballast tank. 4. Insert tank and attach front & back hold downs, great stuff the sides. 5. Run fuel fill and fuel ...
