Shore Power Adapter 30 to 15 Amp Solution
Published date: April 16, 2012
  • Boat Type: Boat Type
The plan is to have a circuit breaker on all AC and DC power lines.
Blue Sea AC Panel for 30amp to 15amp for Shore Power.
To simplify wiring, the plan is to feed 15amp AC to Battery Charger and keep as many components on DC as possible.
Forum feedback
http://www.macgregorsailors.com/forum/viewtopic.php?f=8&t=20163
Published by: macr
Model Year: 1996
Share
Related Mods
  • 12V Plug, Screen
    12V Plug, Screen
    Electrical - - December 1, 2019
    This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
  • Rewiring
    Rewiring
    (A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
  • Rewiring
    Rewiring
    No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
