New gate valve
Published date: April 29, 2012
  • Boat Type: Boat Type
Replaced old gate valve, with a larger 3" one.
Published by: bugman
Model Year: 1996
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Sloppy Rudder Control Horns
    Miscellaneous - - December 11, 2011
    I've made a number of small modifications to the rudder control of my 26M to help remove slop from the control system. This is one that I've actually measured - The control arm inside the hull of the 26M attaches to the rudder horn via a single cross...
