Cabin-top solar panels
- Boat Type: Boat Type
I mounted a pair of 12-watt Sunwize Solcharger "vandal-resistant" solar panels on top of my cabin, forward of the hatch, to keep my batteries charged up between jaunts. The panels are 11" x 13", so they still permit the hatch to open more than 18 inches (I haven't measured, but it's plenty enough to vent out galley fumes).
The Solcharger panels are made on a thick fiberglass panel, and topped with shatter-proof plastic resin instead of glass. They are strong enough to walk on. To fit them on the curved cabin top, I split a length of PVC pipe in half and glued the halves to the cabin top with 5200. I separated them by a couple of inches, to make room for the lowered mast. Then I used "cable clams" to seal the power cable cutouts where I threaded them into the cabin.
I connected the panel cables in series to a length of 12-gauge marine cable, and threaded that through the spaces between the cabin top and the headliner, then led it back to the battery compartment. As the panels are rated at 24 watts total, I added a charge controller with dual output to charge each battery separately.
The panels have stood up perfectly and they've kept my batteries at peak charge through the last winter.
Published by: Rick Westlake
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
